Toshiba e555- says add comp paper
  • chas101
    • Jul 2025
    [Misc] Toshiba e555- says add comp paper
    Toshiba e555- says add comp paper when trying to copy with ADF using Legal size paper. Has anyone ever seen this on that series, I don't know if its a sensor or board problem on the top feeder, works fine off the glass.
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: Toshiba e555- says add comp paper
    run the adjustments (min/max) for the side guides on the adf and this should fix this issue.
      • 23008
      as in "add computer paper"? 11" x 15"? Yes clearly there is some problem with original width detection. =^..^=
      • chas101
        Thanks Mr Spock , I will try that. Do you happen to know the adj. procdure?
        • chas101
          It works ok for letter R on adf.
          • Mr Spock
            • Aug 2006
            • 2064
            put paper guides all the way in (min adjustment) and perform 05-367
            put paper guides all the way out (max adjustment) and perform 05-368
            • chas101
              Thanks for the advice I really appreciate it, I will give that a try.
              • chas101
                [QUOTE=chas101;304040]Thanks for the advice I really appreciate it, I will give that a try.[/QU
                Unfortunately that didn't work, any other suggestions? It does work on 8.5 by 11 letter R.
                • Mr Spock
                  • Aug 2006
                  • 2064
                  I do not have one of this but the previous models had 2 or 3 sensors that determined length on the original tray. I would suspect one of these is not working correctly. look in the service manual for the test procedure in 03 mode.
