hi we have a estudio c2040 fax installed... few days back client called us and he said when we recive fax the fonts are not in shaped or not in formed ... i told him to re initialize he fax like 08-9001 and *1-100 but nothing has changed . print and copy well.. need help...thanks
fonts on RX fax deformed
Re: fonts on RX fax deformed
Do you mean, like a single line of type being slightly squashed? Line errors on fax transmissions are very common, and no fault of the machine. For less line errors and longer transmission times turn On ECM. Error Correction Mode will make the machine re-try errored lines until they come through accurately. The additional tries means that it will take longer for the faxes to come through. To get to the real source, advise the customer to contact their telephone service provider. =^..^=If you'd like a serious answer to your request:
