Toshiba 3510c - Diagonal banding on cyan only
  • sambo
    • May 2011
    • 60
    Hi,I was getting a CE40 error due to cyan not printing well.I have managed to get the cyan to print enough to now no longer CE40 on me, but there is noticeable banding with cyan. See PDF attached.Would anybody be able to help me with this issue?Thanks!
  • Gregg
    Re: Toshiba 3510c - Diagonal banding on cyan only
    Needs developer.
    • didi2005
      • May 2011
      • 401
      Insufficient developer or magnetic roller problem.
      • sambo
        • May 2011
        • 60
        Thanks very much guys. I'll try some developer.....$330!!! farrrkkkkkGood thing the copier was cheap!
        • Gregg
          I have a whole set of developer cheap if your interested.
          • JustManuals
            • Jan 2006
            • 9838
            http://www.justmanuals.com
            Paul@justmanuals.com
            • jamesyboy
              toner monkey
              • Jul 2010
              • 188
              there were probs with mag rollers tosh changed the roller to a fluted type
              before you spend youre wonga on dev try scuffing up thr mag roller surface with fine sandpaper works for me
              • sambo
                • May 2011
                • 60
                Cheers mate, I will try that. Any visual cues that might indicate it's the roller?
                • didi2005
                  • May 2011
                  • 401
                  Check the mag. roll surface...
                  New design mag. roll got lines pattern, similar to e232...
                  • esam ramadan
                    • 199
                    clean laser and try
                    • jamesyboy
                      toner monkey
                      • Jul 2010
                      • 188
                      it will appear as very little dev attracted to mag roller surface but have a lot more attraction after you scrub up the roller surface try a section and rotate the roller to see if attraction increases
                      • sambo
                        • May 2011
                        • 60
                        Thanks for all the tips guys.
                        I've attached 3 pictures showing the amount of developer, and the mag roller.
                        1. I'm afraid I'm not sure how much developer should be added, does it appear that there is enough?
                        2. You can sort of see the banding on the mag roller on the one side. Should I still scuff it up?
                        Thanks again for your help.
                        • jonezy999
                          just one copy??
                          • Feb 2010
                          • 952
                          Hi Mate
                          Did you have a broken rear charge block @ corona to cause all these issues? I would check this before you proceed from here.
                          You defiantly need to dump that dev, clean the unit out, polish that mag roller with a dry rag and the back of your fingernail until it no longer feels gritty. Then drop a full new bottle of genuine dev in. reassembled the unit and initilize the dev. Calibrate the machine and bobs ya mothers brother.
                          Do you have the manual for this machine, I see Paul has offered it and if you aren't familiar with this model then buy it before you do any of the work i just suggested. U will need the manual to run up the dev and calibrate.
                          I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
                          • sambo
                            • May 2011
                            • 60
                            (No broken charge block.)
                            I've scuffed up the roller, but the banding is still evident.
                            I guess I will replace the developer and see if that does the trick.
                            Thanks again for the help.
                            • Gregg
                              P.M.sent
