toshiba 351c updating to latest firmware get error loadModule
+ More Options
Posts
  • dry_torch
    • Sep 2012
    • 11
    [Error Code] toshiba 351c updating to latest firmware get error loadModule
    Could anyway help with this error?
    2GB Kingston, formatted to FAT
    using 80GB Seagate HDD (also tried with original HDD, same error)
    using es5310 firmware bought from justmanuals.
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: toshiba 351c updating to latest firmware get error loadModule
    that requires the 451c/351c/281c firmware not 5310c.
    Toshiba firmware is model specific.
    • dry_torch
      • Sep 2012
      • 11
      sorry i meant 3510C
      is that still the wrong one?
      • dry_torch
        • Sep 2012
        • 11
        Originally posted by dry_torch
        sorry i meant 3510C is that still the wrong one?
        Also, how to find current firmware on the 351c? I think i may need to update stepwise?
        • sdrawkcab
          Confused & Bewildered
          • Jun 2009
          • 317
          As Mr Spock said, you must have the correct firmware for the model, you cant use 3510c firmware for this model.
          Some days, it's just not worth chewing through the restraints
          • canonbundy
            • Jun 2012
            • 607
            Just like the others said - Firmware between models will not work, also the older machines may reject some of the later USB Keys (try an older 1GB key), there are Service Codes etc. which also need to be entered to enable correct machine operation.
            • dry_torch
              • Sep 2012
              • 11
              I was told that this fw is suitable for es310c.Also what happens after you press 0&8 when powering on. I.e what should the screen be displaying?
              • dry_torch
                • Sep 2012
                • 11
                Sorry I meant es351c, (small keys on the phone)
                • canonbundy
                  • Jun 2012
                  • 607
                  Pressing 0 & 8 and powering on will put you into Setting Mode and depending which Code you enter, the Display should read 'CONTACT YOUR NEAREST TOSHIBA TECH' .
                  • dry_torch
                    • Sep 2012
                    • 11
                    Thx for the reply Canon Bundy.I have a few questions, hopefully you can answer:1. When I press 0&8, I end up with " cannot find hdd data" and not the above display? The hdd has been replaced but not formatted, and only C&3 then 3. Do you know how I can proceed further?2. If the fw I have is not for the machine, what should it be and the name of it?
                    • canonbundy
                      • Jun 2012
                      • 607
                      Dry Torch, 08-900 will display your current F/W however as you have replaced the HDD, you can no longer access 08 Mode.
                      Assuming you have the correct F/W and it has been unzipped to the ONLY Folder on your Compatible USB Key, you need to open the Folder & Copy the File 'MENTUSB 0' to the Root Directory of the Key.
                      1/. Insert the Key into M/C > HOLD 4 & 9 > Power ON.
                      If the Display doesn't tell you 'Wrong Key' or something similar then you may be ok - the Display will then show up to 6 items with a '*' symbol beside each Item (these will be automatically updated when the Start Button is pressed) BUT we DO NOT want to do this as conflicts can occur and display 'HDD UPDATE FAILED' - Select ONLY 'SYSTEM' and 'HDD' together (untick the others by entering their numbers) > press Start (takes about 10 mins) if successful then 'UPDATE COMPLETED' will be displayed after the 2 selected Items.
                      If this is successful then Power Off and reinsert Key (as in 1/. above) and select the other Items to be Updated (make sure to DESELECT SYSTEM & HDD).
                      Assuming all is good now, remove Key and enter 08 Mode, check 900 for new Version, enter 947 Init-yes, 1119 init-yes, 693 Init-yes.
                      Shutdown M/C correctly and power up - should operate. Cliff.
                      • dry_torch
                        • Sep 2012
                        • 11
                        Thank you for the reply Cliff.
                        I am still waiting for paul@justmanuals to provide me the right fw to try your suggestion.
                        • JustManuals
                          • Jan 2006
                          • 9838
                          Well that isn't going to happen since you filed a dispute against me on Paypal. The last email I told you I'd get back to you after I spoke to my Toshiba guy, the next morning you filed the dispute. There will be no more emails from me. All correspondence will be done on the PayPal site.
                          • Gregg
                            Shady ass Mofo
                            sellin sh*t you dont even know about, and have the nerve to bash techs who try to help on this site...Theif.
                            • JustManuals
                              • Jan 2006
                              • 9838
                              This end user got what he asked for, if he can't get it working it's on him. I told him beforehand that I don't give support on it.
                              Who did I bash?
                              Get yourself a spell checker, moron.
