e283 with a fax question, setting I cannot find.
  • Travis06
    Tech.
    • 193
    This machine will let the incoming fax ring 6 times before picking up. The customer wants it to pick up after 2 rings. I have seached the fax manual and a few others. I thought it would it might be a funtion mode (1,3) power, but i cant find the setting anywhere. Can anyone point me in the right direction?
    • 23009
    Re: e283 with a fax question, setting I cannot find.
    I've set this before and cannot remember the exact keystrokes, ... but my failing memory is telling me System Menu/Counter > Administrator Settings > enter password > Fax Settings > ...
    • sdrawkcab
      Confused & Bewildered
      • Jun 2009
      • 317
      Some days, it's just not worth chewing through the restraints
      • Travis06
        Tech.
        • 193
        Thanks, I would have never guessed it would have been an 08 code.
        • Travis06
          Tech.
          • 193
          I tried it out today, it was 1,3 372 not 08 mode.
          • Gerald
            • Jan 2011
            • 5
            Thank you, That also Helped me out
              • 23009
              Sorry, I saw a 283 and mentally filled in Konica Minolta bizhub. =^..^=
              • sdrawkcab
                • Jun 2009
                • 317
                Sorry Andy, you're right, I should have put my glasses on!
