I have got a few of these in the field. Any comments (the good/the bad) on how you find they work?
Clients have commented on how very quiet they are, their small size and the excellent print quality on small point sizes.
When transporting to a customer location, techs like the fact that they are half the weight of the e2040c.
It seems that across the industry in the 20-25 cpm speed range the era of the heavy metal frame A3 copiers has come to an end.
Some techs dislike the seemingly flimsy construction of the Transfer Belt unit.
I am told this copier is built with a new Toshiba design concept of affordable Easy Replaceable Units (ERUs). Like on some Lexmark printers, a tech is not suppose to try and fix every component, some components are designed to be replaced in the field rather than maintained.
