STUDIO4520C C3B1 code
  • lavinius
    [Error Code] STUDIO4520C C3B1 code
    Hi all,
    I had to empty the waste toner few days ago and after doing so everything went OK for a few days then got an error to replace black toner, done that, printed a few hundred pages then got the C3B1 error.
    I haven't seen any references to it but from the looks of it the C3B0 is a paper feed error, what is this error?
    The copier jams with the paper no matter from which tray I print, it goes past the fuser and it jams right after it, would appreciate any help
    Cheers
  • jonezy999
    just one copy??
    • Feb 2010
    • 952
    Re: STUDIO4520C C3B1 code
    G'Day mate,
    C3B1 relates to Y-auto toner sensor abnormality.
    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
    • jonezy999
      just one copy??
      • Feb 2010
      • 952
      Also C3B0 relates to the same sensor.
      • lavinius
        ok, i have replaced the toner with a new one and I still get this error, there was a lot of yellow toner left as I could see it through the plastic window, I followed the instruction and pushed the wand in 2-3 times and pulled the rod a few times as well, the error is still present
        do i have to clean something as I can see a little yellow toner spillage, I don't have another developer here to try, could it be the developer?
        If it just needs a clean can someone instruct me? gladly appreciate any help with this as with xmas coming nobody wants to come and have a look at it
        Cheers
        • jonezy999
          just one copy??
          • Feb 2010
          • 952
          • jonezy999
            just one copy??
            • Feb 2010
            • 952
            Just to let you know, You're gunna fucking hate this code if you aren't a tech.
            • lavinius
              thanks mate
              the 08-2692 was at 1 so i left it at that presumably 1 is ON?
              08-2693 was at 40, changed that down to 20
              and the problem still persists ....you're right I hate this thing, I'm going to go buy a can of compressed air and give it a clean
              anything else I can try ?
              • jonezy999
                just one copy??
                • Feb 2010
                • 952
                Compressed air won't do fuck all. Call a tech mate. You are gunna need one.
                • aficio63
                  • Jun 2014
                  • 36
                  Mine was a yellow developer unit depleted of developer...tiger striping. Ran b/w fine...no color
