Double paper feed on 163
  • minolta35
    Trusted tech
    • Apr 2005
    • 87
    There is a problem about many eS 163 machine...Machines feed from paper drawer often double paper.How do I fix it?
    Thanks...
  • xcopytech
    • Aug 2006
    • 1792
    es 163
    I have more that 150 es 163,165,166,167 machine on maintenance and do not have any problem with double feed or any problem with paper supply.
    Maybe you can give more information about your problem
    • minolta35
      Trusted tech
      • Apr 2005
      • 87
      No problem on bypass because it has paper separation roller.But there is no separation material in paper casette.ฤฐt is not enough metal parts at corners.Any ideas?
      • Sbarro
        • 176
        I have about 70 e163,165,166,167 and have no problem either.
        Maybe it's the paper ?
        "A process cannot be understood by stopping it. Understanding must move with the flow of the process, must join it and flow with it"
        What do you despise? By this you are truly known"
        Guess who
        • xcopytech
          • Aug 2006
          • 1792
          just check E rings on claws (metal parts as you say)
          If there is no E rings claws may drop from good position.
          Realy this model do not have any paper feed problem.
          • minolta35
            Trusted tech
            • Apr 2005
            • 87
            I thought that first.But so many customers said same thing.Maybe it happens 2-3% copies but it is not happen their other machine.So not paper.l've cut a little casette lift spring and waiting any call...
