I am currently working on an eS 282. The machine is putting a dark streak perpendicular to the paper path, approx 90mm from the lead edge of the paper. It only does this in the LT direction, not at all the LT-R direction. It happens from both paper trays and the bypass. To this point I have replaced Drum and cleaning blade, found no problems in the fuser section, found no damage or obstructions in the paper path, and have replaced the feed rollers, and the transport and registration clutches. Any other ideas would be greatly appreciated. I am attaching a scan of the counter list that shows the problem. Ignore the dark gray bar at the bottom, not sure where thats from.
Thanks, Dave.
Thanks, Dave.
