Toshiba e 520 saddle finisher
  • SOS
    • Oct 2011
    • 46
    Hello friends,
    does anyones know how to turn on saddle finisher mj-1028, when i plug sorter in, it won't let me select saddle finisher
    thanks
  • sdrawkcab
    Confused & Bewildered
    • Jun 2009
    • 317
    Re: Toshiba e 520 saddle finisher
    Have you fitted the IPC board?
    Some days, it's just not worth chewing through the restraints
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      make sure it is the correct ipc pwb. There is a setting (around 08-1912 check the service handbook) that may need to be changed for the finisher type.
      • SOS
        • Oct 2011
        • 46
        Thank you
        i will check machine
        • SOS
          • Oct 2011
          • 46
          Hello mr. spock,
          I checked service handbook, there is no 08-1912
          • michaelc
            Field Tech
            • Mar 2011
            • 590
            Is there a small board (IPC Board) fitted to the logic board with a 1 connector in it ? When you say you can not select the saddle stitch option, is it shaded out? Do the other finisher functions work?
            It didn't say that I couldn't do it in the manual.
            • SOS
              • Oct 2011
              • 46
              yes, all function work, except saddle stich shaded out, can't select
              thanks
              • emujo
                • Jun 2009
                • 3009
                If the option is there, but greyed out, you must have something configured that is preventing the saddle stitcher from working...It could be the wrong size paper or orientation. It can only stitch 8x11R and 11x17. There is a matrix in the user guide that shows what can be used together, but it may help just to factory default the MFP. Emujo
                • michaelc
                  Field Tech
                  • Mar 2011
                  • 590
                  At least we have got to the stage where we know the finisher itself is working.
                  Just to add to what emujo has said. Do you have staples in the saddle stitch part of the finisher, takes separate staples.
