Toshiba eStudio 281c-error CE40 -----total 491000
  • aco.bk
    • Sep 2012
    • 130
    [Error Code] Toshiba eStudio 281c-error CE40 -----total 491000
    I have Toshiba eStudio 281c showing error CE40 in middle of AUTO CALIBRATION/(when turn on).Please tell m what this error means!? any advice will help....
  • clint@clintsimonsen.com
    • 125
    Re: Toshiba eStudio 281c-error CE40 -----total 491000
    CE40 Image quality control test pattern abnormality: The test pattern is not formed normally. most likely wear and tear parts worn out, Developers/ Drum etc, Look at the Transfer belt and check to see what the test pattern looks like, it should be a Sold and a Half tone Rectangle of each colour.
    • michaelc
      Field Tech
      • Mar 2011
      • 590
      Could be a lot of things. First of all is the transfer belt intact? Have you much experience on these models (just to if not I will have to type more).
      It didn't say that I couldn't do it in the manual.
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • aco.bk
          • Sep 2012
          • 130
          Thanks guys( michaelc andclint@clintsimonsen.com)
          I replaced the toner (C,M,Y) with newone and error was gone.Maybe old the toners was not transported to Develop!
          • emujo
            • Jun 2009
            • 3009
            I wouldn't pat yourself on the back yet...you would get a low toner message long before you started getting the CE40 error code. My guess is the MFP just passed its IQC tests this time, but at the next look, it will be back. It could be low developer, bad t-fer belt, worn drum, cleaning blade (drum/x-fer belt), or dirty sensor. If you print out the test charts, what does the overall color/black CQ look like? EMujo
            • aco.bk
              • Sep 2012
              • 130
              Ok Emujo I will report You soon.
              • Mackieman1967
                FIRST PULL OUT THE BELT CLEANER AND SEE IF IT'S FULL OR THE SPRING IS POPPING OUT if so vacuum it and put it back on the gear assy. Also vacuum or replace the waste toner as this is probably the cause of the cleaner backing up. Good luck.
                • arnh79
                  • 468
                  Well, he's had 4 years to work on it so it's probably fixed or junked by now.
                  Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
