E studio 280: Jams from Ledger & Legal but not 8.5x11 tray
  • ronpfid
    • Oct 2012
    • 67
    Working on a 280, heres what it does
    Top tray 8.5x11 works perfect
    2nd tray legal: Jams at least 1 out of 3
    3rd tray ledger: Most of the time will get one sheet out but jams there after
    on both 2nd and 3rd, when it jams, if you open the 2nd access door from the bottom on the right, the paper is just in those feed rollers, sometimes just an inch above, sometimes the top is almost to the platen type registration roller assembly.
    Any thoughts?
    Thanks!
  • michaelc
    Field Tech
    • Mar 2011
    • 590
    Re: E studio 280: Jams from Ledger & Legal but not 8.5x11 tray
    Have you changed or checked the lower feed sensor?
    It didn't say that I couldn't do it in the manual.
    • canonbundy
      • Jun 2012
      • 607
      Any thoughts?
      Thanks!
      Print Error Report hold 9+Start > Power on > enter 106 > Start, POST the List.
      • ronpfid
        • Oct 2012
        • 67
        I haven't, this machine is new to me, is the sensor "seeable" with the access door open?
        • ronpfid
          • Oct 2012
          • 67
          OK cool will try that and post errors
          • ronpfid
            • Oct 2012
            • 67
            OK, attached are the codes, I also wish I could find an exploded view so I could point to, or get the part module name. I've worked on a ton of machines but this one is new to me and searching around I see they have odd names for a lot of the parts.
            • ronpfid
              • Oct 2012
              • 67
              Do those error codes help at all? thanks!
              • canonbundy
                • Jun 2012
                • 607
                E440 means the lower cover has opened during Printing.
                E320 & E140 means the paper hasn't reached the 2nd paper sensor.
                E300 means the paper hasn't reached the Registration Sensor.
                E010 means the the paper has not gone into the Fuser.
                E020 means the paper has not exited the Fuser.
                Check the Lower Door for Pivot Breakage, dirty Sensor & clean ALL Rollers.
                Check & clean the Fuser inlet guides (E010).
                Check the Fuser Sep Claws (should be 6) for missing, displaced or broken.
                • ronpfid
                  • Oct 2012
                  • 67
                  Thanks, will check all that. The only weird thing is 8.5x11 top tray never jams so it 'seems' the registration on up (fuser, exit, etc.) Must be OK?
                  • canonbundy
                    • Jun 2012
                    • 607
                    Ok dicky lower door paper path sensor.
                    • ronpfid
                      • Oct 2012
                      • 67
                      You don't happen to have the part number for this by any chance?
                      I'm looking at precision rollers part list and cannot tell which switch is which
                      Toshiba E STUDIO 280 Supplies and Parts (All)
