e studio 2830c
  • RoyStor
    • Jun 2025
    e studio 2830c
    I have a Toshiba E Studio 2830c that needs a new paper tray lift motor. I cannot find the part number anywhere in the Parts Manual. Can anyone help me out?
  • canonbundy
    • Jun 2012
    • 607
    Re: e studio 2830c
    Are you sure it's the Motor? Check the soldered wires on the motor - (the Motors never die) - it is a Gearbox Assy and the White Units would break gear Studs or strip gears, which parts were available for, the new Units are Black and never need replacing - which do you have? Check the wiring first.
    • umsombra
      Re: e studio 2830c
      Friend, this engine is actually very dificel to burn when it closes short it just breaks the wire, simply solder it again. But following the name and part number.
      Number: 6LE71176000
      • RoyStor
        Re: e studio 2830c
        It is the black one. But it's not the motor itself that is bad. It's the coupler, if you will, that the shaft from the tray fits in to. The plastic coupler for tray 1 broke into pieces so tray 1 will not lift. Thanks for the reply.
        • RoyStor
          Re: e studio 2830c
          Number: 6LE71176000
          thank you very much for the info! I really appreciate it!
