Would like to use the e 650 document feeder and have the copies exit face up. found out how to do it by selecting SADF in 'Program' tab and changing 08 mode setting 213 to 1. however if the you hit function clear button or machine clears the setting itself, it goes back to ADF selection in 'Program' tab and thus the copies again come out face down and there for is going thru the duplexer. how do you get a face up copy by default when using the document feeder?
