E-Studio 3511 - How can I find out how much life is left on my Drum, Fuser etc?
  • CRC2k
    • May 2008
    • 21
    Hello All,
    How can i Find out how much life is left on my Drum & fuser on the 3511?
    Thanks.
  • Julio119
    • 24
    PM Mode
    Hi there, Turn the machine off, then power it on while holding 6 + Start , let go till you hear a bip. that should take you into the maintenance mode.
    Julio
    Julio_119@yahoo.com
    • Sbarro
      • 176
      Don't forget to press 2 and START after that
      Better way is to print this.
      START+9 / Power ON , then press 103 and START.
      "A process cannot be understood by stopping it. Understanding must move with the flow of the process, must join it and flow with it"
      What do you despise? By this you are truly known"
      Guess who
      • just a tech
        • Jan 2007
        • 332
        And to add something further if i may.. The numbers you will see will only be as accurate as the tech that performed the replacements last. So if they replaced anything and did not reset the maint. count, then you numbers won't be accurate. good luck..
