SHUTDOWN & PRINT ISSUE
  • Forhad
    I have some problem with my Toshiba E-STUDIO 450 Machine.
    1. It denies to shut down (When i tries the it says- `Not allowed this time')
    2. When i print something from my PC, it shows that data is being received but no data were processed and no print is made.
    Can any one please help me out?
    I'll be thankful.
  • emujo
    • Jun 2009
    • 3009
    Re: SHUTDOWN & PRINT ISSUE
    Go into the job queue and delete the stuck job (s). The MFP will not allow you to shut down through the control panel when there is a job in the queue. Could be a corrupt fax job that is causing this. You may have to get the fax service manual to find out how to clear fax image data as it wont be in the job queue. Emujo
      • 8239
      If a fax job is stuck in memory, try: Power On while holding * & 1. Do not release until you hear a beep. Enter 100, press start. This clears all image data.
      • Forhad
        Dear,
        Thanks to both of you for your effort.
        But this didn't solved the problem.
        I have checked in every manner but there was no stucked jobs. Even i tried *+1 and then 100.
        It's still denies to shut down (NOT ALLOWED AT THIS TIME".
        But it shuts down with the timer . Any suggestions please?
        Thanks.
        • michaelc
          Field Tech
          • Mar 2011
          • 590
          Flatten the hard drive and try some firmware. If that does not works. A headbutt or a punch to the display panel helps me with difficult problems.
          It didn't say that I couldn't do it in the manual.
          • JustManuals
            • Jan 2006
            • 9838
            I've got this firmware. Email me if interested in buying it.
            Paul@justmanuals.com
            • Forhad
              Is it (www.copytechnet.com) a marketplace?
              • Forhad
                Thanks for advice. If it is a firmware problem, then how could i get such firmware?
                • Chinnu
                  You try this Code
                  08+690
                  08+947
                  08+693
                  Then not solve pls contact my email i give the firmware
                  chinnu@post.com
                  • Forhad
                    Originally posted by Chinnu
                    You try this Code
                    08+690
                    08+947
                    08+693
                    chinnu@post.com
                    Thanks Dear Chinnu. Will you please see your mailbox?
                    Regards-
                    Forhad
