Toshiba e-studio which recommended UBS Flash Drives ?
  • IDISPLAYS
    • Aug 2025
    Hi,
    I am trying to update a e-studio 2500c, but no matter what memory stick i use i get an error "Inflate Error, please change USB storage or please check ROMDATA"
    Admittedly i only have flash memory drives 2GB and above, could this be this problem?
    I have read you are only meant to use 128mb or 256mb sticks and not cards connected to a memory reader.
    Any one able to shed some light on what the error means or which flash sticks i need to be using?
    I have the correct firmware and the mentusb.o in the root of the flash drive.
    Thanks in advance.
  • Acme
    • Jan 2013
    • 155
    Re: Toshiba e-studio which recommended UBS Flash Drives ?
    yes, too large, We use 1gb and it must be formatted to FAT (not FAT32)
    • IDISPLAYS
      Thanks, what make is your usb stick?
      • Acme
        • Jan 2013
        • 155
        mtrust is the one I use but the other guys use kingston, dont think it matters really.
        • JustManuals
          • Jan 2006
          • 9838
          This is what happens when a novice tries to do a professional's job!
          • michaelc
            Field Tech
            • Mar 2011
            • 590
            I still have 256mb and 512mb for the older models and have worked fine for years. I keep them in my man drawer now in case of emergencies along side the radiator key, spare car key and batteries.
            It didn't say that I couldn't do it in the manual.
            • stockman123
              • 128
              yes I still have 512mb and still works but I also use a 8GB too
              • MUMMIM
                • Jan 2008
                • 125
                you need read in the service handbook, it will guide you update correct your firmware
                • Mr Spock
                  Vulcan Inventor of Death
                  • Aug 2006
                  • 2064
                  Toshiba had a firmware file that gave this error. Download another version and see if that works.
                  • stockman123
                    • 128
                    well is it the most current file if not you need it
                    • Jedenco
                      • 39
                      i use Ativa micro SD card USB drive with a 1GB micro SD card. works great for me.
