We have replaced the customer's genuine Toshiba Cyan toner with 2 brand new genuine Toshiba Cyan toners ... the machine goes thru the motions of adding toner only to say add Cyan Toner. The photo sensor appears to be fine at the back of the machine. Nothing sounds stuck and we cleaned out the opening to the dev unit to ensure there wasn't toner packed in so tight the dev unit auger would get stuck. Would the ATDS be the problem for this one? We're going to rip out the developer unit and see if there's anything obvious there as well.
Thanks.
Thanks.
