2550c display locked up
+ More Options
Posts
  • de144
    • Feb 2012
    • 15
    I have a 2550C that has locked up 4 times since October. The display is in the splash screen showing checking system do not power off. Have to do a hard reboot to clear then it takes a couple minutes before Ready screen comes up. When I got to the machine last week screen was in wait/warming and could not power off except again having to do a hard reboot. I've updated firmware twice in the past month, turned off the sleep modes, and reseated connectors. Anyone else seen this?
  • stockman123
    • 128
    Re: 2550c display locked up
    I've SEEN THIS A LOT ONE OF 2 THINGS TRY THE HDD FIRSTS IF THIS ISNT IT CHANGE THE SYSTEM BOARD USING THE EPROMS FROM THE BOARD IN THE MACHINE SO ALL THE THING STAY THE SAME IN YOUR MACHINE WITH THE ISSUES. CONTACT ME BACK IF I HAVENT EXPLAINED THIS ENOUGH SO YOU DONT MAKE ANY MISTAKES ILL BE ONLINE HERE ALL DAY
    • canonbundy
      • Jun 2012
      • 607
      Try cleaning or replacing the RAM DIMMS.
      • mark77
        Remove the touchscreen panel from the copier. Open the panel up then insulate the ribbon cable from the panel you have just removed. Hope this helps.
        • jamesyboy
          toner monkey
          • Jul 2010
          • 188
          I would start with a firmware upgrade before spending any wonga on parts
          • didi2005
            • May 2011
            • 401
            Go to 5C mode and check HDD SMART info, make sure the HDD is ok.
