estudio 350 problem
  • esam ramadan
    • 199
    estudio 350 problem
    the paper stop at registration roller. this happens just when using 1st cassette
    but 2nd cassette is working well thanks for any ideas
    by the way the feeding unit replaced but no use
  • Acme
    • Jan 2013
    • 155
    Re: estudio 350 problem
    Mine was the Registration clutch, just had one the other day.
    • esam ramadan
      • 199
      thank you my friend but the 2nd cassette is working good?
      • arnh79
        • 468
        It can still be the registration clutch. As they age the response time can slow so paper feeding from 1st cassette jams but because it took more time for the paper to travel from tray 2 the clutch had a chance to activate.
        Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
        • Acme
          • Jan 2013
          • 155
          Yes my second tray worked fine as well. but the first tray would jam and if it didnt jam the lead edge was 2 inches off. Theres also a sensor towards the rear of the reg. roller you could try and blow out. it kind of hard to spot but its there.
          • Riyadh hossain
            there is a cover beside the registration roller,lock system,you can change it I hope problem will be solved.
            • buuluu
              • Apr 2014
              • 49
              Hi Rya
              You check the spring of paper guiding at the place where paper begins transfering to regbist roller. I have trouble with this , only first tray miss feed other is ok. When I checked the paper guide at front regist roller and found out it's spring is lost. replaced another one It was ok.
              • esam ramadan
                • 199
                thanks alot my friends i will try
                • stockman123
                  • 128
                  try changing the cassette for some reasons the ha a bad mold and some cassetees are trouble some
                  • esam ramadan
                    • 199
                    thanks my friend allready i did that but the same problem
