Have a real issue with over toned Magenta have Magenta Developer on the way but is there some steps or tricks that will keep this from happening?
Toshiba 3500C Magenta thick as frosting
Re: Toshiba 3500C Magenta thick as frosting
Got the answer so I thought I would post back the solution.
I found that the corona block had broke releasing the charge blade giving me a low charge on the drum making it thick like frosting
would have thought that there would have been an error produced but I only got the magenta density sensor out of range.
Thanks for reading -
Thanks for posting solution. Too many ask questions, get answers, but never share the end result. Sharing the fix helps all of us.Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?Comment
