securedownload.jpgI've attached an image of the problem for you to check out. Only on bold black print. I've replaced the drum, the developer,and the fuser (the consensus on a previous post) to no avail. I know 100% it's not the fuser, as the image is that way on the drum well before it hits the fuser. I also doubt very seriously that it's the xfer belt, as it only happens on black jobs. This led me to believe it was probably the developer, borrowed one from another customer, no change. Thinking perhaps a bad charge unit on the drum assy? But that feels like I'm reaching. Any advice would be appreciated, as long as you read the post in it's entirety, and don't start telling me to try something on the fuser, or developer. LoL Thanks again.
ES 6530 Smokey black background on large black font.
Re: ES 6530 Smokey black background on large black font.
It ended up being the LSU slit glass. Kinda sucks to get to with my big arms, and hands. Ended up removing the EPU, and Xfer unit. Manually rotating the LSU shutter gear to gain access to the K LSU slit glass. -
have you ever tried to change the trans bely blade this takes take of most ot those isses
