estudio 205se feed components
+ More Options
Posts
  • axyun
    • Aug 2007
    • 1323
    I tried to get service manual and parts list for the 205se series but couldn't find it. I got the 205L /305/355etc and I believe the parts components for trays are the same but want confirmation. I assume the pickup (41306719000), feed (6LE69833000) and separation (6LH46302000) are correct rollers.
    Please advise. Also what is difference between 205L and 205se and why no manual or supplemental manual listed for 205se series. Your help is very much appreciated. Frank/ActionPhotocopy
    • 23010
    Re: estudio 205se feed components
    As far as I can see the 205L uses exactly the same rollers as the 205SE, but I'm seeing 1/2 moon rollers for both. Is that what you're seeing?
    Toshiba E STUDIO 205 Cassette Paper Feed Tires, Genuine (Z8790)
    The reason you don't see a parts manual is because Toshiba uses an application called RIBON to look up parts for all manuals.
    • axyun
      • Aug 2007
      • 1323
      I saw what you did but those half moon shaped rollers are for the estudio 163/203, Precision roller has a listing of other machines that don't apply. I have both the 163/203 sm and pc and the 205l/305/355/455 sm and pc and the 163/203 use the half moon shaped tires which looks exactly like the Sharp ar201 series machines after the modification. The 205L/305 etc use totally different rollers which are round. It uses a pickup which is a double roller on a small shaft and then a separation and feed roller set.
        • 23010
        The standard roller set that goes into the majority of segment 3 & 4 machines is: 6LH34608000
        Toshiba E STUDIO 352 Paper Feed Kit, Genuine (J5842)
        It's the same tires, just as a set.
        • axyun
          • Aug 2007
          • 1323
          Thanks David.
