estudio 356 C580 error
  • Acme
    • Jan 2013
    • 155
    Customer wanted to add a finisher to a E356 we sold,
    Had a trade in that had mj1101 finisher on it, tested fine on the trade in. Removed IPC and all necessary parts to add finisher, install,comes up c580. changed 08-4548 to 0 still c580. brought it all back to the shop and plugged it back into the doner machine and works fine. Am I missing something?
    • 22999
    Re: estudio 356 C580 error
    What firmware level are the finisher and converter PWB at?
    • Acme
      • Jan 2013
      • 155
      Jesus, they need to match/have firmware for a finisher? WTF
        • 22999
        Yes, true. =^..^=
        • Acme
          • Jan 2013
          • 155
          if I upgrade the F/W to the machine will it jive with the IPC card all at the same time?
            • 22999
            Nope. You'll require a special jig to upgrade the firmware for the finisher, and the converter board. It's an entirely separate operation, and totally unlike upgrading machine firmware. =^..^=
            • Acme
              • Jan 2013
              • 155
              GREAT, Toshiba can blow me..
                • 22999
                I hope you two have a good time together. =^..^=
