Toshiba 256se F 101-4 error
  • altu
    • Jun 2025
    Dear
    I have machine its give error F101-4 (HDD Problem)
    I tired to reset through 0 and 8 but its not going in that mode so i decided to install new hard disk
    please any one give me how to install in firmware in new hard disk or any other way without change hard disk
    please let me know.
    • 22999
    Re: Toshiba 256se F 101-4 error
    Have you read the service handbook section on HDD replacement? =^..^=
    • altu
      No Sir i dnt have service book to change HDD replacement if you give details send in this mail
      callemster@gmail.com
      Thanks thanks
        • 22999
        You might not have noticed, but I don't hand out free manuals. There are plenty of places that sell electronic manuals. Sadly to say, our local purveyor of manuals has passed away.
        You'll have no trouble finding another manual seller. =^..^=
        • tech07
          • Aug 2008
          • 409
          Passed away ? Really sad. I bought some test charts from him. I know some did not like him. I considered him a valuable asset for info..
          • laitang
            • Nov 2012
            • 627
            F101-4: Partition mount error (The HDD cannot be connected (mounted) caused by damage to the "/work" partition.)
            1. Turn the power of the equipment OFF and check the connection of the HDD.
            - Connector and harness check
            - Check if the connector pins of the HDD are bent.
            - Check if HDD for other equipment is not installed.
            - Check if SRAM for other equipment is not installed.
            2. If the error still occurs after step 1, perform the following.
            - Perform [3C] - [5] (Key Backup Restore) and check that each Key Status is "OK".
            - If not, recover the key (copy "SRAM Key Status" to "FROM Key Status" or vice versa).
            3. If the error persists after step 2, perform
            [5]+[C]+[POWER]→2. Recovery F/S→3. /work, and then restart the equipment.
            4. If the error persists after step 3, perform
            [5]+[C]+[POWER]→3. Initialize HDD→2. /work, and then restart the equipment.
            5. If the error still persists after step 4, perform the following.
            - Perform [3C] - [3] (Format HDD), and then install "System Software (HD data)" with [49] - [4].
            Notes:
            • dellt
              • Dec 2011
              • 5
              Can anyone help me find System Software for Toshiba-STUDIO256SE/306SE/356SE/456SE PLEASE!!!!!!!
              • calcnet
                • May 2016
                • 8
                • calcnet
                  • May 2016
                  • 8
                  Unfortunately.... total
                  bads in root partition ...after all procedure error is F101-6....all backup keys is ok...but patient is ...dead
                  Amin
                  price is 300 euro + vat.... New HDD from Toshiba with software & install
                  • didi2005
                    • May 2011
                    • 401
                    Re: Unfortunately.... total
                    Originally posted by calcnet
                    [ATTACH=CONFIG]33001[/ATTACH][ATTACH=CONFIG]33002[/ATTACH][ATTACH=CONFIG]33003[/ATTACH]
                    Amin
                    Based on your SMART info screenshot, id c5 is 0 which normally no need to change HDD...What u need to do is perform 3C to format HDD and reinstall firmware...
