Toshiba Estudio 455 Scanning to PC in Color CQ issue
  • Doug James
    • Jan 2012
    • 935
    [CQ] Toshiba Estudio 455 Scanning to PC in Color CQ issue
    I just installed this machine used and not real familiar with scanning on these machines yet. But attached is the scan I get when scanning to PC.
    How can I adjust this or find the info how to. Have all the manuals but can't seem to pinpoint where to start... Thanks so much for any help !!
  • Sperman
    • Apr 2013
    • 2
    Re: Toshiba Estudio 455 Scanning to PC in Color CQ issue
    Looks like the adf needs to be re set up using the pegs that are attached to the rear bracket. Loosen all screws inset pegs close adf tighten up again.
    This will square the feeder up and if you download the install instructions for this adf you will find all the info you need to move lead edge and top edge margins and to further adjust skew.
    Hope this helps.
    Steve
    • Doug James
      • Jan 2012
      • 935
      Hope this helps.
      Steve
      Too cool, Thanks so much. I bet your right... Thanks Again !!
