toshiba
  • junidexy
    • Sep 2013
    • 32
    toshiba
    SKMBT_C25314090907040_0001.jpgSKMBT_C25314090907040_0002.jpgSKMBT_C25314090907040_0003.jpg some problem in toshiba 282 machine like this picture.give the solution in this problem(i changed drum and developer but no useed)
  • sagar4
    • Dec 2012
    • 127
    Re: toshiba
    Originally posted by junidexy
    [ATTACH=CONFIG]26329[/ATTACH][ATTACH=CONFIG]26330[/ATTACH][ATTACH=CONFIG]26331[/ATTACH] some problem in toshiba 282 machine like this picture.give the solution in this problem(i changed drum and developer
    but no useed)
    Did you replace the charge wire and Grid.
    "Broken again"
    • Riyadh hossain
      Re: toshiba
      [ATTACH=CONFIG]26329[/ATTACH][ATTACH=CONFIG]26330[/ATTACH][ATTACH=CONFIG]26331[/ATTACH] some problem in toshiba 282 machine like this picture.give the solution in this problem(i changed drum and developer but no useed)
      1) laser unit
      2)main charger related problem such as connector or spark somewhere
      • jamesyboy
        toner monkey
        • Jul 2010
        • 188
        Re: toshiba
        main charge receptacle mounted on rear frame : make sure grid has correct connection
          • 23009
          Re: toshiba
          I had a shorted transfer corona block cause this. =^..^=
