e Studio 855SE recently refurbed
    • 23009
    What's wrong with this picture?
    Hint: On each printed page there is one or two 1mm dots. =^..^=
  • mckinley
    Chief Twiddler
    • Dec 2006
    • 150
    Re: e Studio 855SE recently refurbed
    I tend to remove the middle drum finger, then there's a code for transfer timing (08 - 841 from the top of my head & on x-bridge it's 08 - 2960 i think), set that code to 0
    This usually sorts out the issues, also sorts E010 jams
    If you get one that's a pain, you can also adjust the solenoid for the drum fingers ( it's on the rear frame inside ), but you would have to remove the exit duct which sits above the fuser to gain access to the screws on the solenoid.
    Regards.
    Happiness Is The Road.
      • 23009
      I think that's a wrong answer. Look closer. =^..^=
      • bigwul
        • Jun 2014
        • 60
        It's obvious - your Wet and Wild yellow enamel metallic nail polish ​has come off your thumbnail.........
        • mckinley
          Chief Twiddler
          • Dec 2006
          • 150
          ah i see you were pointing out the upside down finger that trashed the drum?
            • 23009
            Not quite trashed, but definitely shorter life. Apparently it prevented the oscillation, so it wore only one area/rotation. I find it interesting that the drum claws were worn/not new, just removed and re-installed wrong.
            I've also seen them bent so that it snags every page, and tries to drum wrap. =^..^=
              • 23009
              The Wet and Wild is for threadlocker. I don't mind if you paint your nails though. Include a photo.
              Use the same color on all 10 (or 20). =^..^=
