I have a Toshiba es3530c that is printing and scanning ok but when I try to copy it sends out either a blank copy or a sky shoot. I replaced memory with no change. It is almost like what happens if you try and copy a check or cash. Any thoughts?
Sky shoot when copying
Re: Sky shoot when copying
Well you've ruled it down to a board problem, but which? The scan tells you that the CCD and scanner are functioning properly. The prints indicate that the print engine is functioning. It will be either the system or logic PWB. I'm leaning toward Sys PWB, myself.
Hint: Never replace system and logic boards simultaneously. And follow the backup procedure in the manual. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
Different model machine ,but I had a 232 that was spitting out weird black copies when I tried to copy, I re-seated the ccd connectors and the problem never came back....Comment
