Toshy eS6540 with CD81
    • 23009
    This machine will go ~10K before collecting toner rocks in the vertical auger that feeds the 2nd transfer waste bottle. I vacuum out the augers, tap on the tubes to break loose the rocks, and hand drive the augers until they're clear. 10K later, I'm back again.
    I can't imagine that there could be a heat buildup issue in the ADU unit. It's an office environment, 70F 25% humidity. Where are these toner rocks coming from? I want then to stay away.
    It's got 3.4M prints, 98% monochrome. The 2nd transfer unit has been updated to the new part number. Motor M11 runs fine in 03-241 ... when there aren't any toner rocks. And I wouldn't expect a new motor to act any different.
    I watched the auger system operate for quite a while. M11 comes on every 20 seconds, and runs for about 20 seconds, then repeats. 2nd transfer waste should be minimal. I can't imagine there being very much 2nd transfer waste. Perhaps the interval could be changed to run longer, or take shorter breaks.
    It's OEM toner. Umm ... ok, that's all I can think of. What do you think? =^..^=
  • mckinley
    Chief Twiddler
    • Dec 2006
    • 150
    Re: Toshy eS6540 with CD81
    Did you fit the modded augers as well as the new black housing?
    If you did, take a look at the mylar flappers at the end of the modded auger, they've been made to long IMO. I cut them down so they just reach the hole.
    Make sure to clean the bushings on the end of all the augers & the plastic shafts with some PTFE or other similar lubricant (should be able to spin the bushings by hand when placed on the shafts & they should spin fast.
    I've had to attend escalations for several where the mods have been done & all i've done is clean as above & the fault usually doesn't come back, there is a possibility however that the driver board in the ADU frame has an intermittent issue.
    Regards.
    Happiness Is The Road.
      • 23009
      Regards.
      I'll have to look at the augers. I don't know the answer to that question. It spins easily (without toner rocks). The auger ends were clean, no toner past the rubber seals. Thanks McKinley. =^..^=
