Any know the yield of Toshiba Estudio 5540C, Color and B/W Developers
  • Doug James
    • Jan 2012
    • 935
    [Misc] Any know the yield of Toshiba Estudio 5540C, Color and B/W Developers
    I have a customer looking at one of these machines and needs to know the operating cost. Thanks so much for any help
  • mckinley
    Chief Twiddler
    • Dec 2006
    • 150
    Re: Any know the yield of Toshiba Estudio 5540C, Color and B/W Developers
    The devs don't have a set life span on the 5540/6540/6550 ( & the previous range 5520 etc... )
    The toner contains 17% dev & there is a section of the dev unit which removes old dev as new toner / dev is supplied. This is the reason these machines must be levelled with a spirit level ( bullseye variety, so that it's level in all directions )
    As long as you dont run the charge grids until they become heavily contaminated, then the devs will last for a very very long time ( ie i have schools that have done 3 million copies without a dev being fitted )
    Regards.
    Happiness Is The Road.
    • Doug James
      • Jan 2012
      • 935
      Regards.
      This is a HUGE help, Thanks so much !!
      • excanonguy
        • Jun 2008
        • 173
        Just be aware that the dev is very expensive if you do have to replace! I had one color on a 5520 give an error code ( I forget now is been a few years) and I ended up having to do the dev for that color it was about $500. for the bottle here in Canada from Toshiba....
          • 23009
          The book says 248K but I've seen a lot more yield, and a lot less yield. Most notably yellow toner density errors on the third recall (10K total color count), and still hadn't had yellow developer changed.
          I'd like to ask: "What were you waiting for? Obviously doing nothing isn't working." =^..^=
