very light copies (washed out) so i replaced dev and calibrated for 2 to 3 min. but wouldn't stabalize between 233 and 244, it wouldn't even get to 200. another weird thing in 05 mode there were some simulations i couldn't adjust, it wouldn't except the simulation numbers. any ideas appreciated. thanks t
E-232
Hi,
you have to check also the value of toner, as you mention 233 - 245 is bias developer charge. this both value is response each other. regarding your problem, if the value toner is not change automatic and even you have adjusted by increase the value but not change anything, you have to check sensor toner, and developer unit, or gear inside machine just in case if the mixer won't rotate.
regardsComment
Hello,
This is an "old" thread but I'll bring this up anyway just incase someone else see it. Of course, check the things already mentioned. The fact he said it wouldn't "take" some of the values he was entering is weird. Check 08-257 and make sure the counters match. You aren't getting a "check total counter" message are you? If so you might have a board or ROM problem. I've seen the 08 codes go bonkers, as well as the 05 codes from a bad chip.
Just a thought...I will not give you service manuals or firmware.Comment
