EStudio163 Firmware Win8.1
  • NeoMatrix
    Senior Tech.
    • 3513
    Is it still possible to get firmware for the ES163 superseded model to suite Win8.1 64bit USB drivers?
    **** update*****
    Will the old XP 32bit Toshiba Viewer install on 64bit system and operate?
    Tnx...
  • NeoMatrix
    Senior Tech.
    • 3513
    Re: EStudio163 Firmware Win8.1
    Does any one know of any software that will enable ES163 USB print driver to function from Win8.x 64 bit?
    Can later versions of "Toshiba Viewer" be backward compatible for this model?
    tnx
      • 23009
      I doubt it. You probably already know that the eS163 was released in February 2006, making it 8 years old, and 7 years prior to the initial design of Win 8.1
      • NeoMatrix
        Senior Tech.
        • 3513
        Would an external USB to ethernet breakout box work on this machine?
        If I convert the usb to ethernet would the Win8 64 drivers work on the ethernet?
        This machine has low clicks on the clock. It's ashame to throw it.
        ******Updated *******
        Can someone confirm the version of software for this machine is :
        T280SY0W131JIG.bin
        Also if possibe the MD5 signature for the file.
        tnx
        • ivovb
          • 695
          Support | Toshiba America Business Solutions
          browse down to model and check v 1.06 - it works:
          This package supports Windows XP, Server 2003, Vista, Server 2008, Server 2008 R2, Windows 7, Windows 8 in 32 and 64 installations.
          BR
          I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
