estudio 355 duplex copy
  • Doctor
    • Sep 2010
    • 133
    Hello,
    I have this estudio 355. It copies come upside down during duplex. Is there a setting that can correct this?
    • 23009
    Re: estudio 355 duplex copy
    Most copiers have the option to select Short Edge Binding or Long Edge Binding. From the operator's manual I don't see that optional choice. You may have to rotate your originals 90 degrees (and copy paper) to get the correct duplex binding option. =^..^=
    • NeoMatrix
      Senior Tech.
      • 3513
      Sounds like your scanning top-bottom not top-to-top or printing with a file similar top-to-bottom double sided format.
      • Doctor
        • Sep 2010
        • 133
        Thanks all I've been able to solve the problem. It occurs only when feeding the original short edge feed. The solution is to select Image Direction from Edit button on the control panel during copy. But you will have to do this every time. To make it default I use 08- 628 set to 1.
