Toshiba 6530c Error E580 Replaced entire duplex transport assembly still same problem
  • sagar4
    • Dec 2012
    • 127
    [Error Code] Toshiba 6530c Error E580 Replaced entire duplex transport assembly still same problem
    Good day techs. I have a Toshbia E6530C that jams most of the time. Stops in the center transport unit (bridge Unit) then pops up an error E580. I might be lucky to get 1 sheet out of 10 to feed all the way through. I have replaced the whole unit from another machine still same problem. Any ideas would be great.
    Stop jam at the bridge unit
    "Broken again"
  • ivovb
    • 695
    Re: Toshiba 6530c Error E580 Replaced entire duplex transport assembly still same pro
    Did You go through whole Toshiba troubleshooting for this error?
    BR
    I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
    • sagar4
      • Dec 2012
      • 127
      BR
      Yes so I can assume nobody else has an idea. Thanks
      "Broken again"
        • 23009
        You're going to love this one. I had a eS 855 a while back that gave E580s and a bunch of other codes. Well it seems that the enduser didn't have the requisite 20A outlet, so they did the "twist" so the plug would almost fit in a 15A outlet. The power quality analyzer found 3.8 vac ground to neutral. I don't remember what the other codes were, but there were some finisher communication codes in there.
        I had another eS2500C that eventually gave E580 codes, that had a bad converter board, and bad logic board, and bad NVRAM, and firmware, and color calibration. This was one of those three day extravaganzas, where I was shuttling back and forth from the office with parts. =^..^=
        • sagar4
          • Dec 2012
          • 127
          Thank you Blackcat4866 it was exactly as you said he has a 15amp outlet using a adapter to fit it into it. lol Thank you so much.
          "Broken again"
            • 23009
            Congratulations! =^..^=
