problem of 452
  • Riyadh hossain
    problem of 452
    In 0+8 mode say SRAM ERROR, DOES IT INITIALIZE? AND BOOT UP PROBLEM , I have changed SYS board, hdd, ram,lgc board,panel board and perform Firmware update.some time it show Machine information error
    this problem specially occur when copier remain stop for about 2 minute, If I off and on instantly it does not occur, Any help???
    • 23009
    Re: problem of 452
    Did you install all these boards in a single operation? If yes, there is no opportunity to backup the data from the logic to the system or visa versa. If no, did you follow the procedure to backup the data from the logic board to the system board or visa versa? I suspect not.
    If it were me, I would install one of the original boards (SYS or LGC), then backup the data to the new board. The manual describes this procedure quite nicely. Once the new board has been backed up, then you can install the other new board and back that one up too. I would re-load firmware also at the completion of this process.
    If you still cannot boot up, I'd replace the NVRAM. =^..^=
