Part number
  • draph
    • 132
    Part number
    Searched high and low. Can't find a parts manual for the E Studio 282. Need the part number for the power supply.
    • 23009
    Re: Part number
    Toshiba parts manuals are consolidated as an application called RIBON, or if you're a qualified dealer you can use a web version called WebRIBON, on the fyi.toshiba.com website. So you you won't find standard PDF parts manuals like you're used to.
    What exactly are you looking for? =^..^=
    • draph
      • 132
      Re: Part number
      Working on a 282. Don't normally do Toshibas but its a request from a good client. Have a C430 code. Everything in the fuser checks out good. So I'm thinking power supply. Need the part number so I can locate one.
        • 23009
        Re: Part number
        If you're not that familiar with Toshiba, you may not know that you'll need to reset the error. Use simulation 08-400. If it's in a fuser error condition the value will be other than zero. Enter service mode 08 > 400 > press Clear > Zero > Enter > power Off/On.
        • draph
          • 132
          Re: Part number
          Yea, did that.
          • laitang
            • Nov 2012
            • 627
            Re: Part number
            Check the stable of outlet voltage, use an automatic stabilizer if need
            • Mad_Coachman
              • 99
              Re: Part number
              Try replacing the thermistors(6LA89105000) first...If you still have C430 then you probably have a blown fuse on the PS.
              • Blizzoo
                • Aug 2013
                • 608
                Re: Part number
                C430 is a Low Temp error?don't have the manual
                Get the board to an electrician and put him to inspect and replace triacs on lamp supply.
                • draph
                  • 132
                  Re: Part number
                  Yes. I'm pretty sure the triacs are the problem. Thermistors checked out good but I replaced them anyway just to be certain. I just need a part number so I can find a power supply PWB.
                    • 23009
                    Re: Part number
                    PS-HVT-371: 6LA89173000
                    Sorry for the delay. It's well hidden in the parts reference. I looked for a while last night and gave up. Found it today. =^..^=
                    • draph
                      • 132
                      Re: Part number
                      Thank you Blackcat. You're the best. Hope to return the favor one day.
