2830c dept. code to restrict color
  • CVBS
    • Jul 2014
    • 24
    Customer has a 2830c. Nobody has a dept. code in the office, but they want color to be restricted and b/w available for everyone. In department management, I have created a "Color" department code. I did not activate a limit as those who are authorized to print in color do not want a quota placed on them and I enabled no limit black. This has essentially preventing anyone from being able to print or copy (I did enable color scanning and fax) in color unless they enter a code. This works great from the machine itself...if you attempt to change the copier to color, it prompts for a dept. code. However, my problem is that when someone prints something in color from their computer, they are not prompted for a code and the job is printed in color. I have set this up many times in the past without issue. Not sure what is going on. Anyone have a suggestion?
  • arnh79
    • 468
    Re: 2830c dept. code to restrict color
    Look under TopAccess in the Admin section. Under the "General" hyperlink there is a function called "Department Code Enforcement". If that is set to "print" then it won't prompt for a code and will output any print job sent to it without restriction.
    Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
      • 23009
      In addition, you'll need to "Prompt for account code" in the driver. Otherwise all the color print jobs will be rejected. =^..^=
