Wait message during copying
  • JVC
    • Jun 2011
    • 151
    Hello
    I have an es4520c that keeps pausing during large copy jobs. If I run a 50 copy job it will pause about every 10 copies or so. I have seen simular problems and either the machine is low on toner or replacing the thermopiles is the issue. I have checked both with no change. Has anyone seen this and have suggestions?
    Thank you
  • arnh79
    • 469
    Re: Wait message during copying
    Are any of the process units past PM? I've seen that series keep trying to add toner to compensate for low developer levels.
    Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
    • Hansen88
      • 1079
      I have had the thermopiles just be dirty causing problem like that ,even though they looked ok. I just swabbed them with a q tip and problem went away.
      • Hansen88
        • 1079
        Also once i had one lamp that was burned out with no kind of codes. Machine was slow to heat and need to wait in middle of runs.
        • JVC
          • Jun 2011
          • 151
          Thank you for the answers. I cleaned them and it seems to be working. I ran 100 copier straight before I could not get 10 out.
