Toshiba e Studio 2330C network dropout
  • Alex1
    • Oct 2012
    • 285
    Hi,
    i installed a Toshiba e studio 2330c the machine is connected to the network but out of nowhere the machine will dropout either after 20min or the next day. You will see on the display Network Initializing. The previous machine that was in its spot was on the network fine. Any ideas is appropriated?
    • 23009
    Re: Toshiba e Studio 2330C network dropout
    What happens when you connect it via crossover to your laptop? =^..^=
    • Alex1
      • Oct 2012
      • 285
      Im not too familiar with I.T or the network side. What can I do to test on the laptop? What should I get as w result? Thank you.
        • 23009
        You can connect your laptop via a crossover cable directly to your laptop, simulating a network. On your laptop hard-set a Static address in the same address range as the MFP.
        Once connected you can test print as often as you like.
        There are several possible outcomes, including these:
        1) same result as the customers network, confirming that you have a hardware problem.
        2) it works fine, never dropping off the network, indicating that the source of the problem is on the customers network.
        3) something totally different happens.
