A.S.A.P. Estudio 352
  • altech
    • Jul 2014
    • 41
    How do I manually add toner to see if the toner bottle is turning?
    • 23007
    Re: A.S.A.P. Estudio 352
    Most likely the bottle is not turning because the keyed plunger/gear in the end is broken or deformed. In the pictures, the plunger is charcoal gray, with flats on two sides, to make the bottle rotate. A feature at the center of the bottle presses the plunger, to engage the drive. So the motor turns, but the drive is not transmitted. Usually the plunger crushes or twists, or just crumbles. All the pictures attached are intact plungers. If the plunger is flush with the dish shaped blue cup, it's broken. It's the same toner feed assembly in the eS28, eS35, eS45, and all the 350, 352, 353, 450, 452, 453, etc, etc.
    You want to manually add toner? Remove the cartridge, dump some toner on paper, then pour it into the orifice in the developing unit. If the plunger is broken, no toner will leave the bottle the usual way. =^..^=
