E-Studio 5540C CA00 code
+ More Options
Posts
  • tnrtt
    • 156
    I pulled the EPU unit out and removed drums. Most of black developer was gone. Replaced entire EPU assy with a known good one. Drums, transfer belt, dev units. The machine powered up without the code. Black and white is fine, but getting color banding in color mode. Color(all three) half tone bands about an inch thick. I get them in single color mode also. The bands are opposite of feed direction. They slowly fade out about 2 inches from the bottom. Never seen anything like it and need help.
    Last edited by tnrtt; 02-24-2015, 04:15 AM. Reason: didn't notice the yellow bands at first
  • tnrtt
    • 156
    Re: E-Studio 5540C CA00 code
    Lots of views, no replies. The problem has been solved.
    • arnh79
      • 469
      What was the solution?
      Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
        • 23010
        It helps to see an image when it's a quality issue. =^..^=
        • tnrtt
          • 156
          The samples were in a subsequent post
          http://www.copytechnet.com/forums/to...0-samples.html
          • bigwul
            • Jun 2014
            • 60
            Did you find the cause though - even though no one seems to have been able to help - a lot of people benefit from some one finding the cause and reporting the solution....
            • tnrtt
              • 156
              Something in the drum drive unit. Haven't troubleshot the unit yet.
