toshiba 720
  • shrum1340
    • Jun 2008
    • 44
    toshiba 720
    I need part #'s for thermisters and thermostats for a toshiba 720.
    It keeps kicking a c447.
    Thank you!!!
  • mckinley
    Chief Twiddler
    • Dec 2006
    • 150
    6LE09610000 THMS-HTR-U-390 ( Upper )
    4406379760 THMS-HTR-L-300 ( Lower )
    6LA07172000 THRMST-340-FUS ( there are 2 of these in the fuser )
    they are the pt numbers for UK machines anyway, but i guess they may be the same elsewhere.
    i would check a few things though before fitting them, such as the connector on the rear of the fuser tray / connector on rear frame for any damage or small fragments of paper, also make sure all the door switches are operating incase the machine thinks it's still ready with a door open, if this happens & the customer slides out the fuser / trans. belt unit, it will break the fuser connection while it thinks it's ready & throw a fuser error.
    Happiness Is The Road.
