-STUDIO 5520C Code C022
  • Gabriel
    • Jun 2006
    • 141
    Toshiba e-STUDIO 5520C C022
    After CD81 (clogges pipes) the machine shows a C022, any idea?The color drums doesn't turn
    any help is welcome
  • laitang
    • Nov 2012
    • 627
    Re: -STUDIO 5520C Code C022
    [C022] Developer unit mixer motor-YMC locking error
    (1) Pull out the EPU tray and perform the output check (03-115) to check if the 3 outputs of the YMC developer unit mixer are rotating normally.
    When it is not rotating:
    (2) Is the connector of the YMC-developer unit mixer motor connected securely?
    (3) Check if the harness or connector of the YMC-drum motor is disconnected or open-circuited.
    (4) Check if the YMC-developer unit mixer motor is abnormal.
    (5) Check if the drive gear array has any abnormality such as breakage.
    When it is rotating:
    (6) Check if developer material is excessively supplied to each YMC-developer unit.
    (7) Check if the drive gear array of each YMC-developer unit has any abnormality such as breakage.
    • Gabriel
      • Jun 2006
      • 141
      laitang
      Thank you for your response,
      everything looks fine and running 03-115 does nothing but the developers units movement are free and smooth,
      The original problem was CD81, after cleaning the pipes the CD81 was cleared and pop-ups C022
      Any help is welcome
