Re: -STUDIO 5520C Code C022
laitang
Thank you for your response,
everything looks fine and running 03-115 does nothing but the developers units movement are free and smooth,
The original problem was CD81, after cleaning the pipes the CD81 was cleared and pop-ups C022
Any help is welcome
[C022] Developer unit mixer motor-YMC locking error
(1) Pull out the EPU tray and perform the output check (03-115) to check if the 3 outputs of the YMC developer unit mixer are rotating normally.
When it is not rotating:
(2) Is the connector of the YMC-developer unit mixer motor connected securely?
(3) Check if the harness or connector of the YMC-drum motor is disconnected or open-circuited.
(4) Check if the YMC-developer unit mixer motor is abnormal.
(5) Check if the drive gear array has any abnormality such as breakage.
When it is rotating:
(6) Check if developer material is excessively supplied to each YMC-developer unit.
(7) Check if the drive gear array of each YMC-developer unit has any abnormality such as breakage.Leave a comment:
Toshiba e-STUDIO 5520C C022
After CD81 (clogges pipes) the machine shows a C022, any idea?The color drums doesn't turn
any help is welcomeTags: None
