E-Studio 161 win7x64 drivers
  • Rael
    • Mar 2015
    • 5
    For the e-Studio 161 Copy/printer, Toshiba never produce drivers for windows 7 x64, and considering that the machine use a GDI language, there's no way to use a generic driver.
    So looking around, i found that sharp produce the same machine, calling it AR-M160. You can find the drivers on sharp site.
    You must install manually the printer, forcing windows to use the sharp drivers, but they works fine.
    For the scanner, actually I haven't find a solution, but I'll keep you in touch.
  • kennethsross
    Re: E-Studio 161 win7x64 drivers
    Hi Rael
    So can I assume you are using this via USB, rather than via the network?
    Windows 7 has a pretty large collection of drivers - I would be surprised if the 161 wasn't included.
      • 23006
      If it is USB, you won't be able to scan. Must use TCP/IP to scan. =^..^=
