error code e 030 on estudio 305
  • Riyadh hossain
    • Aug 2025
    Signal code e030 on estudio 305 .I have replaced exit sensor but nothing helpful. Any suggestion please???
  • Luther
    • May 2006
    • 682
    Re: error code e 030 on estudio 305
    That is paper remaining after power on, could be the upper drawer paper feed sensor, registration sensor, or the exit sensor
    • Riyadh hossain
      It's the problem of lgc board, do u know someone which parts of lgc board can be damaged??? Plz help
        • 23010
        It's certainly possible that you have a logic board problem. I had one that would not lift tray #2 intermittently, yet would try to feed from the tray that hadn't lifted. That one was a logic board issue.
        More likely though, you should spend a few minutes with your manual checking each paper sensor in 03 mode. I'll bet dollars to donuts that you have a defective photointerrupter.
        E030 code is a paper present error during power on (like E000 on Kyocera), but does not specify which sensor. It's up to you to figure out which sensor.
        We've had many bad photointerrupters lately. They aren't always diagnosable from 03 mode. You may need to read output voltage for each sensor at the connector on the logic board. Again more manual reading to identify the appropriate pins. =^..^=
        • Riyadh hossain
          My first problem was 2nd drawer lift motor ,do not rotate. There was a(pf )in lgc board after direct that (pf) it shows error code e030.
            • 23010
            Are you asking something? I don't see a question. =^..^=
            • Riyadh hossain
              How did u solved your problem?
                • 23010
                I thought that I was fairly clear, but I'll re-phase my comments:
                It's certainly possible that you have a logic board problem. I had one that would not lift tray #2 intermittently, yet would try to feed from the tray that hadn't lifted. That one was a logic board issue. ...
                This issue was solved by the LGC PWB.
                More likely though, you should spend a few minutes with your manual checking each paper sensor in 03 mode. I'll bet dollars to donuts that you have a defective photointerrupter. ...
                There have been far more events like this, solved by defective photointerrupters. =^..^=
