Toshiba Estudio 2830C developer unit
  • scanmc
    • Mar 2015
    • 183
    I don't normally work on Toshiba machines, but one of my current customers just acquired one of these from a business that moved out of their building. My question is relating to part# 6LH3363000 developer unit - Precision Roller list this as black\yellow is this sold as a pair or individually? Also is developer pre loaded into the units. If someone has a service-parts manual they could email me I would be much appreciative.
    • 23010
    Re: Toshiba Estudio 2830C developer unit
    I think I can help clarify. You will only get one developing unit and one bag of developer. The difference between the black/yellow and the cyan/magenta, is that the black and yellow developing units have drum thermistors attached. Cyan and magenta developing units do not have drum thermistors.
    What I cannot tell you is if you'll get black developer or yellow developer with your developing unit. Maybe you need to specify? =^..^=
