E-Studio 355 Intermittent E20 Jams
  • Buddy
    • Aug 2009
    • 285
    Hi Guys,
    I have a machine that will run 20,30,50 copies and then it throws an e20 code. I have replaced the ADF and letter tray feed rollers.
    Any ideas?
    Thanks much,
    Buddy
    BTW-Does anyone else have trouble doing searches on this site. Seems no matter what I search for, or how I do it, I always get "nothing found."
  • Bicyclerepairman
    • 63
    Re: E-Studio 355 Intermittent E20 Jams
    E020 or EA20?
    • Buddy
      • Aug 2009
      • 285
      Sorry, EO20.
      • gliderider
        • May 2015
        • 131
        Hi:
        Can you provide more information like: How is it jamming, what tray is it jamming from, amount of copies currently on the copier. There is a raft of updates on that model concerning paper jams.
        Andrew
        • Dustp115
          • Mar 2015
          • 11
          There are numerous causes for an E020 jam. Tires, transport ,registration or exit sensors, registration clutch, worn actuators and warn guides and Mylar.
          Check the copies and see it there is a slight image shift often it is a bad registration clutch or the registration and transport actuators,followed by warn paper guides
          • Bicyclerepairman
            • 63
            Originally posted by Buddy
            Hi Guys,
            Any ideas?
            Thanks much,
            Buddy
            Any luck with this issue?
              • 23009
              Try this search engine. You'll get better results:
              Copytechnet Forum Search - Via Google
              It would help even more to get the jam code correct. =^..^=
              • Buddy
                • Aug 2009
                • 285
                Found that a spring post on the exit unit was broken. I replaced the exit unit plastic about a week ago. Still haven't heard back from the customer, so fingers still crossed. This machine would usually jam intermittently on long runs.
                  • 23009
                  Congratulations on your success. Thanks for posting back. =^..^=
