e2050c Dirty
  • didi2005
    • May 2011
    • 401
    e2050c Dirty
    Bottom part of paper get dirty print when copy/print A3 & A4 size...
    It seems that toner from transfer belt is not been cleaned properly, resulting the 2nd transfer roller and drum get dirty...
    After replaced drum, 2nd transfer roller & transfer unit cleaning blade, same problem occur, causing the new 2nd transfer roller dirty...
    Before I replace parts, found the transfer unit rear side is jammed, need to use screw driver to adjust the white bushing then only able to take it out. And found that the transfer belt front side seems fold up compare to rear side...
    Going to order a new transfer belt....Any things that I might miss?
    • 23008
    Re: e2050c Dirty
    I think I'd take a closer look at the black developer and primary charge. If the primary charge is arcing to the drum it will pull developer like in the pictures. Also you may have a worn developer bearing or seal causing developer bias loss. I had a bad black developing unit just Thursday. It had chewed up the drive gears due to the developer flooding out through the seals. =^..^=
    • didi2005
      • May 2011
      • 401
      Re: e2050c Dirty
      Problem resolved after adjust doctor gap...standard 0.6mm cannot...need manual adjust...
        • 23008
        Re: e2050c Dirty
        Congratulations on success, but keep an eye on it. If the mag roller aluminum shaft is worn at the bearing, it's only a short term solution to adjust the doctor blade height. =^..^=
